Validation of a New Method for Stroke Volume Variation Assessment: a Comparaison with the PiCCO Technique
Abstract : This paper proposes a novel, simple and minimally invasive method for stroke volume variation assessment using arterial blood pressure measurements. The arterial blood pressure signal is reconstructed using a semi-classical signal analysis method allowing the computation of a parameter, called the first systolic invariant INVS1. We show that INVS1 is linearly related to stroke volume. To validate this approach, a statistical comparaison between INVS1 and stroke volume measured with the PiCCO technique was performed during a 15-mn recording in 21 mechanically ventilated patients in intensive care. In 94% of the whole recordings, a strong correlation was estimated by cross-correlation analysis (mean coefficient=0.9) and linear regression (mean coefficient=0.89). Once the linear relation had been verified, a Bland-Altman test showed the very good agreement between the two approaches and their interchangeability. For the remaining 6%, INVS1 and the PiCCO stroke volume were not correlated at all, and this discrepancy, interpreted with the help of mean pressure, heart rate and peripheral vascular resistances, was in favor of INVS1.
Complete list of metadatas
https://hal.inria.fr/inria-00429496
Contributor : Taous-Meriem Laleg-Kirati <>
Submitted on : Thursday, January 7, 2010 - 4:07:52 PM
Last modification on : Sunday, April 7, 2019 - 3:00:02 PM
Long-term archiving on : Thursday, September 23, 2010 - 11:07:51 AM
Laleg-Medigue-et-al.pdf
Identifiers
  • HAL Id : inria-00429496, version 2
  • ARXIV : 0911.0837
Citation
Taous-Meriem Laleg-Kirati, Claire Médigue, Yves Papelier, François Cottin, Andry van de Louw. Validation of a New Method for Stroke Volume Variation Assessment: a Comparaison with the PiCCO Technique. [Research Report] 2010, pp.22. ⟨inria-00429496v2⟩
Share
Metrics
Record views
9
Files downloads
73
