Inverse EEG source problems and approximation
We consider the inverse EEG (ElectroEncephaloGraphy) problem that consists in recovering, from measurements on electrodes of the electric potential on the scalp, a distribution of pointwise dipolar current sources located in the brain and modeling e.g. the presence of epileptic foci.
Abstract.leblondpdf.pdf (67.69 Ko)
Télécharger le fichier
leblond_.pdf (295.55 Ko)
