Syscall Interception in Xen Hypervisor - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2009
In the scope of the ANR-08-VERS-017 project Vampire, as part of Task 4 on close loop fuzzing, we performed a feasibility study on system calls interception within the Xen virtualization system. In this report, we present the work done and the results obtained during this study.
Technical_Report_Syscall_Interception.pdf (325.27 Ko) Télécharger le fichier
inria-00431031 , version 1 (10-11-2009)
  • HAL Id : inria-00431031 , version 1
Frédéric Beck, Olivier Festor. Syscall Interception in Xen Hypervisor. [Technical Report] 2009, pp.19. ⟨inria-00431031⟩
286 Consultations
3498 Téléchargements
