Enhancing Real-Time Delivery in Wireless Sensor Networks With Two-Hop Information - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Industrial Informatics Année : 2009
A two-hop neighborhood information-based routing protocol is proposed for real-time wireless sensor networks. The approach of mapping packet deadline to a velocity is adopted as that in SPEED; however, our routing decision is made based on the novel two-hop velocity integrated with energy balancing mechanism. Initiative drop control is embedded to enhance energy utilization efficiency, while reducing packet deadline miss ratio. Simulation and comparison show that the new protocol has led to lower packet deadline miss ratio and higher energy efficiency than two existing popular schemes. The result has also indicated a promising direction in supporting real-time quality-of-service for wireless sensor networks.
tii09.pdf (1.03 Mo) Télécharger le fichier
inria-00431252 , version 1 (11-11-2009)
Yanjun Li, Chung Shue Chen, Ye-Qiong Song, Zhi Wang, Youxian Sun. Enhancing Real-Time Delivery in Wireless Sensor Networks With Two-Hop Information. IEEE Transactions on Industrial Informatics, 2009, 5 (2), pp.113-122. ⟨10.1109/TII.2009.2017938⟩. ⟨inria-00431252⟩
191 Consultations
1126 Téléchargements
