A Programming Environment for Behavioural Animation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Visualization and Computer Animation Année : 2002
Behavioural models offer the ability to simulate autonomous agents like organisms and living beings. Psychological studies have showed that the human behaviour can be described by a perception-decisionaction loop, in which the decisional process should integrate several programming paradigms such as real-time, concurrency and hierarchy. Building such systems for interactive simulation requires the design of a reactive system treating flows of data to and from the environment, and involving task control and preemption. Since a complete mental model based on vision and image processing cannot be constructed in real time using purely geometrical information, higher levels of information are needed in a model of the virtual environment. For example, the autonomous actors of a virtual world would exploit the knowledge of the environment topology to navigate through it. Accordingly, in this paper we present our programming environment for real-time behavioural animation which is compounded of a general animation and simulation platform, a behavioural modelling language and a scenario authoring tool. Those tools has been used for different applications such as pedestrian and car driver interaction in urban environments, or a virtual museum populated by a group of visitors.
inria-00432193 , version 1 (14-11-2009)
Fabrice Lamarche, Frédéric Devillers, Jean François Tailles, Stéphane Donikian. A Programming Environment for Behavioural Animation. Journal of Visualization and Computer Animation, 2002, 13 (5), ⟨10.1002/vis.295⟩. ⟨inria-00432193⟩
78 Consultations
0 Téléchargements
