Contextual effects on protrusion and lip opening for /i,y/ - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
This study investigates the effect of “adverse” contexts, especially that of the consonant /ʃ/, on labial parameters for French /i,y/. Five parameters were analysed: the height, width and area of lip opening, the distance between the corners of the mouth, as well as lip protrusion. Ten speakers uttered a corpus made up of isolated vowels, syllables and logatoms. A special procedure has been designed to evaluate lip opening contours. Results showed that the carry-over effect of the consonant /ʃ/ can impede the opposition between /i/ and /y/ in the protrusion dimension, depending upon speakers.
interspeech09ab.pdf (312.52 Ko) Télécharger le fichier
inria-00433381 , version 1 (19-11-2009)
  • HAL Id : inria-00433381 , version 1
Anne Bonneau, Julie Busset, Brigitte Wrobel-Dautcourt. Contextual effects on protrusion and lip opening for /i,y/. 10th Annual Conference of the International Speech Communication Association - Interspeech 2009, ISCA, Sep 2009, Brighton, United Kingdom. ⟨inria-00433381⟩
209 Consultations
137 Téléchargements
