Error analysis for a class of numerical differentiator: application to state observation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In this note, firstly a modified numerical differentiation scheme is presented. The obtained scheme is rooted in the numerical differentiation method of Mboup M., Join C., Fliess M. and uses the same algebraic approach based on operational calculus. Secondly an analysis of the error due to a corrupting noise in this estimation is conducted and some upper-bounds are given on this error. Lastly a convincing simulation example gives an estimation of the state variable of a nonlinear system where the measured output is noisy.
cdc09DL.pdf (126.03 Ko) Télécharger le fichier
inria-00437129 , version 1 (29-11-2009)
  • HAL Id : inria-00437129 , version 1
Da-Yan Liu, Olivier Gibaru, Wilfrid Perruquetti. Error analysis for a class of numerical differentiator: application to state observation. 48th IEEE Conference on Decision and Control, Dec 2009, Shanghai, China. ⟨inria-00437129⟩
267 Consultations
244 Téléchargements
