Checking Architectural and Implementation Constraints for Domain-Specific Component Frameworks using Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Software components are used in various application domains, and many component models and frameworks have been proposed to fulfill domain-specific requirements. The ad-hoc development of these component frameworks hampers the reuse of tools and abstractions across different frameworks. We believe that in order to promote the reuse of components within various domain contexts an homogeneous design approach is needed. A key requirement of such an approach is the definition and validation of reusable domain-specific constraints. In this paper we propose an extension to the Hulotte component framework that allows the definition and checking of domain-specific concerns. From the components' architecture to their implementations, concerns are defined and checked in an homogeneous manner. Our approach is illustrated and evaluated through the design of an example component-based application for the multitasking and distributed domains.
Noguera_Loiret-SEAA09.pdf (605.1 Ko) Télécharger le fichier
inria-00437954 , version 1 (01-12-2009)
  • HAL Id : inria-00437954 , version 1
Carlos Noguera, Frédéric Loiret. Checking Architectural and Implementation Constraints for Domain-Specific Component Frameworks using Models. 35th Euromicro Conference on Software Engineering and Advanced Applications (SEAA'09), Aug 2009, Patras, Greece. pp.125-132. ⟨inria-00437954⟩
119 Consultations
254 Téléchargements
