Manifold Reconstruction using Tangential Delaunay Complexes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Jean-Daniel Boissonnat
  • Fonction : Auteur
  • PersonId : 830857
Arijit Ghosh
  • Fonction : Auteur correspondant
  • PersonId : 865421
Connectez-vous pour contacter l'auteur
We give a provably correct algorithm to reconstruct a $k$-dimensional manifold embedded in $d$-dimensional Euclidean space. Input to our algorithm is a point sample coming from an unknown manifold. Our approach is based on two main ideas~: the notion of tangential Delaunay complex, and the technique of sliver removal by weighting the sample points. Differently from previous methods, we do not construct any subdivision of the embedding $d$-dimensional space. As a result, the running time of our algorithm depends only linearly on the extrinsic dimension $d$ while it depends quadratically on the size of the input sample, and exponentially on the intrinsic dimension $k$. To the best of our knowledge, this is the first certified algorithm for manifold reconstruction whose complexity depends linearly on the ambient dimension. We also prove that for a dense enough sample the output of our algorithm is isotopic to the manifold and a close geometric approximation of the manifold.
RR-7142.pdf (450.66 Ko) Télécharger le fichier
inria-00440337 , version 1 (10-12-2009)
inria-00440337 , version 2 (16-09-2011)
  • HAL Id : inria-00440337 , version 1
Jean-Daniel Boissonnat, Arijit Ghosh. Manifold Reconstruction using Tangential Delaunay Complexes. [Research Report] RR-7142, 2009. ⟨inria-00440337v1⟩
Collections
INRIA-RRRT
239 Consultations
492 Téléchargements
