Toward higher order event-capturing schemes and adaptive time-step strategies for nonsmooth multibody systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
The report is devoted to the study of higher order time integration methods for multibody systems with unilateral constraints. After a brief presentation of the mathematical modelling of nonsmooth multibody systems, several estimates on the local error of consistency of the Moreau time-stepping scheme are given. Based on these estimates, an attempt at an adaptive time-step strategy is presented on academic examples. Finally, higher order event-capturing methods are designed by coupling implicit Runge-Kutta schemes and the Moreau's time-stepping scheme.
RR-7151-v2.pdf (406.48 Ko) Télécharger le fichier
inria-00440771 , version 1 (15-12-2009)
inria-00440771 , version 2 (25-08-2010)
  • HAL Id : inria-00440771 , version 2
Vincent Acary. Toward higher order event-capturing schemes and adaptive time-step strategies for nonsmooth multibody systems. [Research Report] RR-7151, INRIA. 2009, pp.31. ⟨inria-00440771v2⟩
287 Consultations
151 Téléchargements
