Dependency Constraints for Lexical Disambiguation
We propose a generic method to per- form lexical disambiguation in lexicalized grammatical formalisms. It relies on de- pendency constraints between words. The soundness of the method is due to invariant properties of the parsing in a given gram- mar that can be computed statically from the grammar.
Logique en informatique [cs.LO]
