Pharo by Example - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ouvrage (Y Compris Édition Critique Et Traduction) Année : 2009
Pharo by Example
Pharo by Example, intended for both students and developers, will guide you gently through the Pharo language and environment by means of a series of examples and exercises. This book is made available under the Creative Commons Attribution-ShareAlike 3.0 license.
PBE1-2009-10-28.pdf (6.04 Mo) Télécharger le fichier
inria-00441463 , version 1 (16-12-2009)
  • HAL Id : inria-00441463 , version 1
Andrew Black, Stéphane Ducasse, Oscar Nierstrasz, Damien Pollet, Damien Cassou, et al.. Pharo by Example. Square Bracket Associates, pp.352, 2009, 978-3-9523341-4-0. ⟨inria-00441463⟩
289 Consultations
1184 Téléchargements
