Accurately Detecting Symmetries of 3D Shapes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2005
Many shapes and geometrical models exhibit symmetries. These symmetries are sometimes explicitly represented in the model. However, symmetry information is often lost in automatic transla- tions between file formats. Using symmetries, one can, for example, manipulate models through coherent re-meshing or intelligent mesh editing programs. We present two algorithms that automatically retrieve symmetries in a 3D model through the use of an intermediate set of functions: The Generalized Even Moments
Poster.pdf (21.39 Mo) Télécharger le fichier
Format : Figure, Image
inria-00441631 , version 1 (17-12-2009)
inria-00441631 , version 2 (18-12-2009)
  • HAL Id : inria-00441631 , version 1
Aurélien Martinet, Cyril Soler, Nicolas Holzschuch, François X. Sillion. Accurately Detecting Symmetries of 3D Shapes. Eurographics Symposium on Geometry Processing (Poster session), Jul 2005, Vienna, Austria. 2005. ⟨inria-00441631v1⟩
258 Consultations
264 Téléchargements
