From spider robots to half disk robots - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1994
Jean-Daniel Boissonnat
  • Fonction : Auteur
  • PersonId : 830857
Olivier Devillers
Sylvain Lazard
We study the problem of computing the set F of accessible and stable placements of a spider robot. The body of this robot is a single point and the legs are line segments attached to the body. The robot can only put its feet on some regions, called the foothold regions. Moreover, the robot is subject to two constraints: Each leg has a maximal extension R (accessibility constraint) and the body of the robot must lie above the convex hull of its feet (stability constraint). We present an efficient algorithm to compute F. If the foothold regions are polygons with n edges in total, our algorithm computes F in O(n^2 log n) time and O(n^2 alpha(n)) space where alpha is the inverse of the Ackerman's function. Omega(n^2) is a lower bound for the size of F.
Spider_Robot_IEEE94.pdf (208.9 Ko) Télécharger le fichier
inria-00442776 , version 1 (22-12-2009)
  • HAL Id : inria-00442776 , version 1
Jean-Daniel Boissonnat, Olivier Devillers, Sylvain Lazard. From spider robots to half disk robots. IEEE International Conference on Robotics and Automation, 1994, San Diego, United States. pp.953-958. ⟨inria-00442776⟩
84 Consultations
133 Téléchargements
