Persistence and Migration for C++ Objects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1989
We describe the support to object management of the distributed object-oriented operating system SOS. We discuss the integration of object migration and storage into C++ programs, a language not designed for that purpose. The necessary support is split between the compiler and a run-time object management system. Migration and storage preserve the type and structure of the objects, which may be user-defined and arbitrarily complex. Our mechanisms are simple, generic, and require little programmer intervention. The key elements are dynamic classes, a generalized pointer type which allows to efficiently refer to an object, pre-requisite objects, and a mechanism for object re-initialization.
Mots clés
C++
Shapiro1989.pdf (772.73 Ko) Télécharger le fichier
inria-00444602 , version 1 (05-04-2024)
  • HAL Id : inria-00444602 , version 1
Marc Shapiro, Philippe Gautron, Laurence Mosseri. Persistence and Migration for C++ Objects. ECOOP'89, Proc. of the Third European Conf.on Object-Oriented Programming, The British Computer Society, 1989, Nottingham, GB, United Kingdom. pp.191--204. ⟨inria-00444602⟩
Collections
INRIA INRIA2
117 Consultations
4 Téléchargements
