Fragmented Objects for Distributed Abstractions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 1994
Mesaac Makpangou
  • Fonction : Auteur
  • PersonId : 829535
Marc Shapiro
Fragmented Objects (FOs) extend the object concept to a distributed environment. The abstract view of a FO is a single, shared object, of which the distribution is hidden to clients. In the concrete view the FO designer controls (if wished) the distribution of data and function and of the communication between fragments. FO programming is supported by the FOG language, an extension of C++, and by a toolbox of predefined FOs. The FOG compiler ensures distributed type-safety of both the external and internal interfaces, verifies the encapsulation of FO instances, and automatically generates whatever coercions are necessary for marshalling/unmarshalling between layers. Currently, the toolbox contains mainly classes of primitive FOs such as RPC and multicast communication channels. We present the basic fragmented object concepts, the toolbox of predefined FOs, the FOG language and its compiler. We also present an example of a distributed application, the SOS Naming Service, structured as FOs. Finally, we point out the benefits of the FO approach
Makpangou1991.pdf (2.31 Mo) Télécharger le fichier
inria-00444614 , version 1 (05-04-2024)
  • HAL Id : inria-00444614 , version 1
Mesaac Makpangou, Yvon Gourhant, Jean-Pierre Le Narzul, Marc Shapiro. Fragmented Objects for Distributed Abstractions. Thomas L. Casavant and Mukesh Singhal. Readings in Distributed Computing Systems, IEEE Computer Society Press, pp.170--186, 1994. ⟨inria-00444614⟩
Collections
INRIA INRIA2
117 Consultations
2 Téléchargements
