PerDiS: design, implementation, and use of a PERsistent DIstributed Store - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2000
The PerDiS (Persistent Distributed Store) project addresses the issue of providing support for distributed collaborative engineering applications. We describe the design and implementation of the PerDiS platform, and its support for such applications. Collaborative engineering raises system issues related to the sharing of large volumes of fine-grain, complex objects across wide-area networks and administrative boundaries. PerDiS manages all these aspects in a well defined, integrated, and automatic way. Distributed application programming is simplified because it uses the same memory abstraction as in the centralized case. Porting an existing centralized program written in C or C++ is usually a matter of a few, well-isolated changes. We present some performance results from a proof-of-concept platform that runs a number of small, but real, distributed applications on Unix and Windows NT. These confirm that the PerDiS abstraction is well adapted to the targeted application area and that the overall performance is promising compared to alternative approaches
PDIUPDS_lncs1752.pdf (404.89 Ko) Télécharger le fichier
inria-00444644 , version 1 (07-01-2010)
Paulo Ferreira, Marc Shapiro, Xavier Blondel, Olivier Fambon, João Garcia, et al.. PerDiS: design, implementation, and use of a PERsistent DIstributed Store. Sacha Krakowiak and Santosh Kumar Shrivastava. Recent Advances in Distributed Systems, 1752, Springer-Verlag, pp.427--452, 2000, Lecture Notes in Computer Science, ⟨10.1007/3-540-46475-1_18⟩. ⟨inria-00444644⟩
165 Consultations
445 Téléchargements
