Non efficiency and non Gaussianity of a maximum likelihood estimator at high signal-to-noise ratio and finite number of samples - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
In estimation theory, the asymptotic efficiency of the Maximum Likelihood (ML) method for independent identically distributed observations and when the number T of observations tends to infinity is a well known result. In some scenarii, the number of snapshots may be small making this result unapplicable. In the array processing framework, for Gaussian emitted signals, we fill this lack at high Signal to Noise Ratio (SNR). In this situation, we show that the ML estimation is asymptotically (with respect to SNR) non efficient and non Gaussian.
RFBL04.pdf (517.83 Ko) Télécharger le fichier
inria-00444829 , version 1 (07-01-2010)
Alexandre Renaux, Philippe Forster, Eric Boyer, Pascal Larzabal. Non efficiency and non Gaussianity of a maximum likelihood estimator at high signal-to-noise ratio and finite number of samples. ICASSP 2004 - 29th IEEE International Conference on Acoustics, Speech and Signal Processing, 2004, Montreal, Canada. ⟨10.1109/icassp.2004.1326209⟩. ⟨inria-00444829⟩
140 Consultations
306 Téléchargements
