Function Approximation based on Estimated Arithmetic Operators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
This article reports preliminary results on hardware operators for function evaluation with moderate average accuracy. The obtained operators provide a small average error on the input domain but a few large errors may occur for some very infrequent arguments. The proposed approximation method combines two methods: i) approximation using low-degree polynomials with small and sparse coefficients; ii) operators for addition based on estimated arithmetic and integer power operators (x^2, x^3) with reduced accuracy. Typical delay reduction is about 20-50% and 15-30% for silicon area reduction compared to previous results.
Fichier non déposé
inria-00446527 , version 1 (12-01-2010)
  • HAL Id : inria-00446527 , version 1
Arnaud Tisserand. Function Approximation based on Estimated Arithmetic Operators. 43th Asilomar Conference on Signals, Systems and Computers, Oct 2009, Pacific Grove, California, United States. ⟨inria-00446527⟩
107 Consultations
0 Téléchargements
