Noise cancellation using two closely spaced microphones: experimental study with a specific model and two adaptive algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2006
We consider the speech enhancement problem in a moving car through a blind source separation scheme involving two closely spaced microphones. We propose the use of a double fast Newton transversal filter algorithm (DFNTF) to estimate and suppress coherent noise components from speech, and a model of signal mixtures able to represent correctly the effect of microphones spacing. We also consider the realistic case where the noises at the sensor inputs contain non-coherent components. The simulation results show that the DFNTF algorithm, when controlled by a Voice Activity Detector (VAD), is able to fully cancel the correlated noise components from speech.
No file
Dates and versions
inria-00451442 , version 1 (29-01-2010)
Identifiers
  • HAL Id : inria-00451442 , version 1
Cite
Mohamed Djendi, André Gilloire, Pascal Scalart. Noise cancellation using two closely spaced microphones: experimental study with a specific model and two adaptive algorithms. IEEE International Conference on Acoustic, Speech and Signal Processing, May 2006, Toulouse, France. ⟨inria-00451442⟩
142 View
0 Download
Share
