Automatic transcription of piano music based on HMM tracking of jointly-estimated pitches - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
This work deals with the automatic transcription of piano recordings into a MIDI symbolic file. The system consists of subsequent stages of onset detection and multipitch estimation and tracking. The latter is based on a Hidden Markov Model framework, embedding a spectral maximum likelihood method for joint pitch estimation. The complexity issue of joint estimation techniques is solved by selecting subsets of simultaneously played notes within a pre-estimated set of candidates. Tests on a large database and comparisons to state-of-the-art methods show promising results.
080825_Eusipco_emiya_final.pdf (174.5 Ko) Télécharger le fichier
inria-00452620 , version 1 (02-02-2010)
  • HAL Id : inria-00452620 , version 1
Valentin Emiya, Roland Badeau, Bertrand David. Automatic transcription of piano music based on HMM tracking of jointly-estimated pitches. Proc. Eur. Conf. Sig. Proces. (EUSIPCO), Aug 2008, Lausanne, Switzerland. ⟨inria-00452620⟩
242 Consultations
278 Téléchargements
