Two-phase algorithms for the parametric shortest path problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A {\em parametric weighted graph} is a graph whose edges are labeled with continuous real functions of a single common variable. For any instantiation of the variable, one obtains a standard edge-weighted graph. Parametric weighted graph problems are generalizations of weighted graph problems, and arise in various natural scenarios. Parametric weighted graph algorithms consist of two phases. A {\em preprocessing phase} whose input is a parametric weighted graph, and whose output is a data structure, the advice, that is later used by the {\em instantiation phase}, where a specific value for the variable is given. The instantiation phase outputs the solution to the (standard) weighted graph problem that arises from the instantiation. The goal is to have the running time of the instantiation phase supersede the running time of any algorithm that solves the weighted graph problem from scratch, by taking advantage of the advice. In this paper we construct several parametric algorithms for the shortest path problem. For the case of linear function weights we present an algorithm for the single source shortest path problem.
chakraborty.pdf (164.77 Ko) Télécharger le fichier
inria-00455816 , version 1 (11-02-2010)
  • HAL Id : inria-00455816 , version 1
Sourav Chakraborty, Eldar Fischer, Oded Lachish, Raphael Yuster. Two-phase algorithms for the parametric shortest path problem. 27th International Symposium on Theoretical Aspects of Computer Science - STACS 2010, Inria Nancy Grand Est & Loria, Mar 2010, Nancy, France. pp.167-178. ⟨inria-00455816⟩
Collections
STACS2010
98 Consultations
322 Téléchargements
