Partial Order Reductions for model checking temporal epistemic logic over interleaved mulit-agent systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We investigate partial order reduction for model checking multi-agent systems by focusing on interleaved interpreted systems. These are a particular class of interpreted systems, a mainstream MAS formalism, in which only one action at the time is performed. We present a notion of stuttering-equivalence, and prove the semantical equivalence of stuttering-equivalent traces with respect to linear and branching time temporal logics for knowledge without the next operator. We give algorithms to reduce the size of the models before the model chechking step and show preservation properties. We evaluate the technique by discussing the experimental results obtained against well-known examples in the MAS literature
aamas.pdf (236.63 Ko) Télécharger le fichier
inria-00458132 , version 1 (19-02-2010)
  • HAL Id : inria-00458132 , version 1
Alessio Lomuscio, Wojciech Penczek, Hongyang Qu. Partial Order Reductions for model checking temporal epistemic logic over interleaved mulit-agent systems. AAMAS 2010 : International Conference on Autonomous Agents and Multiagent Systems, May 2010, Toronto, Canada. ⟨inria-00458132⟩
Collections
CONNECT
37 Consultations
118 Téléchargements
