Using Aspect Oriented Modeling to localize implementation of executable models
Executable models are essential to define the behavior of models, such as constraints put on model elements. However their implementation crosscut multiple model elements. Model semantics will facilitate Model Driven Development, without it, Design and Implementation won?t necessarily represent different abstractions of the same system. This paper introduces a mechanism to query executable models and weave constraints in order to localize their implementation, which improves code redundancy and modularity.
Génie logiciel [cs.SE]
