Forecasting for Cloud computing on-demand resources based on pattern matching
The Cloud phenomenon brings along the cost-saving benefit of dynamic scaling. Knowledge in advance is necessary as the virtual resources that Cloud computing uses have a setup time that is not negligible. We propose a new approach to the problem of workload prediction based on identifying similar past occurrences to the current short-term workload history. We present in detail the auto-scaling algorithm that uses the above approach as well as experimental results by using real-world data and an overall evaluation of this approach, its potential and usefulness.
RR-7217.pdf (620.49 Ko)
Télécharger le fichier
Format : Figure, Image
