New interface
Conference papers
A Learning Algorithm for Top-Down XML Transformations
Abstract : A generalization from string to trees and from languages to translations is given of the classical result that any regular language can be learned from examples: it is shown that for any deterministic top-down tree transformation there exists a sample set of polynomial size (with respect to the minimal transducer) which allows to infer the translation. Until now, only for string transducers and for simple relabeling tree transducers, similar results had been known. Learning of deterministic top-down tree transducers (DTOPs) is far more involved because a DTOP can copy, delete, and permute its input subtrees. Thus, complex dependencies of labeled input to output paths need to be maintained by the algorithm. First, a Myhill-Nerode theorem is presented for DTOPs, which is interesting on its own. This theorem is then used to construct a learning algorithm for DTOPs. Finally, it is shown how our result can be applied to XML transformations (e.g. XSLT programs). For this, a new DTD-based encoding of unranked trees by ranked ones is presented. Over such encodings, DTOPs can realize many practically interesting XML transformations which cannot be realized on first-child/next-sibling encodings.
A preliminary extended version can be found at http://www.grappa.univ-lille3.fr/~niehren/Papers/learn-dtop/long.pdf .
Complete list of metadata
Cited literature [26 references]  Display  Hide  Download
https://hal.inria.fr/inria-00460489
Contributor : Joachim Niehren Connect in order to contact the contributor
Submitted on : Tuesday, June 22, 2010 - 1:33:23 PM
Last modification on : Saturday, November 19, 2022 - 3:59:08 AM
Long-term archiving on: : Monday, October 22, 2012 - 12:45:58 PM
File
0.pdf
Identifiers
  • HAL Id : inria-00460489, version 2
Citation
Aurélien Lemay, Sebastian Maneth, Joachim Niehren. A Learning Algorithm for Top-Down XML Transformations. 29th ACM SIGMOD-SIGACT-SIGART Symposium on Principles of Database Systems, Jun 2010, Indianapolis, United States. pp.285-296. ⟨inria-00460489v2⟩
Share
Metrics
Record views
224
Files downloads
253
