Interactive Mediated Reality - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Mediated reality describes the concept of filtering our vision of reality, typically using a head-mounted video mixing display. We can redefine this idea in a more constructive context, applying dynamic changes to the appearance and geometry of objects in a real scene using computer graphics. In this paper, we propose new tools for interactively mediated reality. After describing a new generic framework for achieving this goal, we present a prototype system for painting, grabbing and glueing together real and virtual elements. We also conducted an informal evaluation that provides an initial analysis of the level of interest, usability and current technical limitations of this approach. See http://artis.inrialpes.fr/Publications/2005/GBGS05
2005-AUIC-InteractiveMediatedReality.pdf (820.54 Ko) Télécharger le fichier
posterISMAR.pdf (3.58 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
inria-00463586 , version 1 (23-03-2010)
  • HAL Id : inria-00463586 , version 1
Raphaël Grasset, Laurence Boissieux, Jean-Dominique Gascuel, Dieter Schmalstieg. Interactive Mediated Reality. 6th Australasian User Interface Conference, Jan 2005, Newcastle, Australia. pp.21-29. ⟨inria-00463586⟩
650 Consultations
780 Téléchargements
