Dynamic Canvas for Non-Photorealistic Walkthroughs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
The static background paper or canvas texture usually used for non-photorealistic animation greatly impedes the sensation of motion and results in a disturbing “shower door” effect. We present a method to animate the background canvas for non-photorealistic rendering animations and walkthroughs, which greatly improves the sensation of motion and 3D “immersion”. The complex motion eld induced by the 3D displacement is matched using purely 2D transformations. The motion eld of forward translations is approximated using a 2D zoom in the texture, and camera rotation is approximated using 2D translation and rotation. A rolling-ball metaphor is introduced to match the instantaneous 3D motion with a 2D transformation. An innite zoom in the texture is made possible by using a paper model based on multifrequency solid turbulence. Our results indicate a dramatic improvement over a static background.
Mots clés
npr_paper.pdf (5.91 Mo) Télécharger le fichier
infinite_zoom.mov (9.04 Mo) Télécharger le fichier
infinite_zoom.mpg (3.75 Mo) Télécharger le fichier
rolling_sphere.mov (14.32 Mo) Télécharger le fichier
rolling_sphere.mpg (6.53 Mo) Télécharger le fichier
spherical_warp.mov (13.56 Mo) Télécharger le fichier
spherical_warp.mpg (6.14 Mo) Télécharger le fichier
walkthrough.mov (26.11 Mo) Télécharger le fichier
walkthrough.mpg (22.07 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
inria-00463592 , version 1 (12-03-2010)
  • HAL Id : inria-00463592 , version 1
Matthieu Cunzi, Joëlle Thollot, Sylvain Paris, Jean-Dominique Gascuel, Gilles Debunne, et al.. Dynamic Canvas for Non-Photorealistic Walkthroughs. Graphics Interface, Jun 2003, Halifax, Canada. pp.121--130. ⟨inria-00463592⟩
826 Consultations
302 Téléchargements
