A 2-stages locomotion planner for digital actors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
This paper presents a solution to the locomotion planning problem for digital actors. The solution is based both on probabilistic motion planning and on motion capture blending and warping. The paper describes the various components of our solution, from the first path planning to the last animation step. An example illustrates the progression of the animation construction all along the presentation.
03SCA.pdf (787.42 Ko) Télécharger le fichier
inria-00473393 , version 1 (22-01-2019)
  • HAL Id : inria-00473393 , version 1
Julien Pettré, Jean-Paul Laumond, Thierry Simeon. A 2-stages locomotion planner for digital actors. ACM SIGGRAPH/Eurographics symposium on Computer animation, Aug 2003, San Diego, United States. pp.258--264. ⟨inria-00473393⟩
160 Consultations
91 Téléchargements
