An experimental evaluation of Wiener filter smoothing techniques applied to under-determined audio source separation - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 2010
Multichannel under-determined source separation is often carried out in the time-frequency domain by estimating the source coefficients in each time-frequency bin based on some sparsity assumption. Due to the limited amount of data, this estimation is often inaccurate and results in musical noise artifacts. A number of single- and multichannel smoothing techniques have been introduced to reduce such artifacts in the context of speech denoising but have not yet been systematically applied to under-determined source separation. We present some of these techniques, extend them to multichannel input when needed, and compare them on a set of speech and music mixtures. Many techniques initially designed for diffuse and/or stationary interference appear to fail with directional nonstationary interference. Temporal covariance smoothing provides the best tradeoff between artifacts and interference and increases the overall signal-to-distortion ratio by up to 3 dB.
techreport_warning.pdf (6.37 Ko) Télécharger le fichier
Dates and versions
inria-00474383 , version 1 (19-04-2010)
inria-00474383 , version 2 (10-12-2010)
Identifiers
  • HAL Id : inria-00474383 , version 2
Cite
Emmanuel Vincent. An experimental evaluation of Wiener filter smoothing techniques applied to under-determined audio source separation. [Research Report] RR-7261, 2010. ⟨inria-00474383v2⟩
219 View
552 Download
Share
