Automatic Image Colorization via Multimodal Predictions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
We aim to color automatically greyscale images, without any manual intervention. The color proposition could then be interactively corrected by user-provided color landmarks if necessary. Automatic colorization is nontrivial since there is usually no one-to-one correspondence between color and local texture. The contribution of our framework is that we deal directly with multimodality and estimate, for each pixel of the image to be colored, the probability distribution of all possible colors, instead of choosing the most probable color at the local level. We also predict the expected variation of color at each pixel, thus defining a nonuniform spatial coherency criterion. We then use graph cuts to maximize the probability of the whole colored image at the global level. We work in the L-a-b color space in order to approximate the human perception of distances between colors, and we use machine learning tools to extract as much information as possible from a dataset of colored examples. The resulting algorithm is fast, designed to be more robust to texture noise, and is above all able to deal with ambiguity, in contrary to previous approaches.
colorisation.pdf (864.26 Ko) Télécharger le fichier
inria-00481552 , version 1 (07-05-2010)
  • HAL Id : inria-00481552 , version 1
Guillaume Charpiat, Matthias Hofmann, Bernhard Schölkopf. Automatic Image Colorization via Multimodal Predictions. European Conference on Computer Vision, Sep 2008, Marseille, France. ⟨inria-00481552⟩
Collections
INRIA INRIA2
256 Consultations
849 Téléchargements
