A Cognitive Radio Based Internet Access Framework for Disaster Response Network Deployment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
In this paper, we propose a cognitive radio based Internet access framework for disaster response network deployment in challenged environments. The proposed architectural framework is designed to help the existent but partially damaged networks to restore their connectivity and to connect them to the global Internet. This architectural framework provides the basis to develop algorithms and protocols for the future cognitive radio network deployments in challenged environments.
RR-7285.pdf (249.2 Ko) Télécharger le fichier
inria-00482593 , version 1 (10-05-2010)
  • HAL Id : inria-00482593 , version 1
Mubashir Husain Rehmani, Aline Carneiro Viana, Hicham Khalife, Serge Fdida. A Cognitive Radio Based Internet Access Framework for Disaster Response Network Deployment. [Research Report] RR-7285, INRIA. 2010. ⟨inria-00482593⟩
267 Consultations
377 Téléchargements
