Self-stabilization with Byzantine tolerance for global tasks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
Self-stabilization is a versatile approach to fault-tolerance since it permits a distributed system to recover from any transient fault that arbitrarily corrupts the contents of all memories in the system. Byzantine tolerance is an attractive feature of distributed systems that permits to cope with arbitrary malicious behaviors. Combining these two properties proved difficult: it is impossible to contain the spatial impact of Byzantine nodes in a self-stabilizing context for global tasks such as tree orientation and tree construction. We present and illustrate a new concept of Byzantine containment in stabilization. Our property, called Strong Stabilization enables to contain the impact of Byzantine nodes if they actually perform too many Byzantine actions. We derive impossibility results for strong stabilization and present strongly stabilizing protocols for tree orientation and tree construction that are optimal with respect to the number of Byzantine nodes that can be tolerated in a self-stabilizing context.
DuboisMasuzawaTixeuil.pdf (309.06 Ko) Télécharger le fichier
inria-00484645 , version 1 (18-05-2010)
inria-00484645 , version 2 (10-02-2011)
  • HAL Id : inria-00484645 , version 1
  • ARXIV : 1005.3367
Swan Dubois, Toshimitsu Masuzawa, Sébastien Tixeuil. Self-stabilization with Byzantine tolerance for global tasks. [Research Report] 2010. ⟨inria-00484645v1⟩
315 Consultations
293 Téléchargements
