Bayesian clustering in decomposable graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Bayesian Analysis Année : 2011
In this paper we propose a class of prior distributions on decomposable graphs, allowing for improved modeling flexibility. While existing methods solely penalize the number of edges, the proposed work empowers practitioners to control clustering, level of separation, and other features of the graph. Emphasis is placed on a particular prior distribution which derives its motivation from the class of product partition models; the properties of this prior relative to existing priors is examined through theory and simulation. We then demonstrate the use of graphical models in the field of agriculture, showing how the proposed prior distribution alleviates the inflexibility of previous approaches in properly modeling the interactions between the yield of different crop varieties.
inria-00487168 , version 1 (28-05-2010)
Luke Bornn, François Caron. Bayesian clustering in decomposable graphs. Bayesian Analysis, 2011, 6 (4), pp.829-845. ⟨10.1214/11-BA630⟩. ⟨inria-00487168⟩
56 Consultations
0 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
