The evolutionary limit for models of populations interacting competitively via several resources - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Differential Equations Année : 2011
We consider a integro-differential nonlinear model that describes the evolution of a population structured by a quantitative trait. The interactions between traits occur from competition for resources whose concentrations depend on the current state of the population. Following the formalism of~\cite{DJMP}, we study a concentration phenomenon arising in the limit of strong selection and small mutations. We prove that the population density converges to a sum of Dirac masses characterized by the solution $\varphi$ of a Hamilton-Jacobi equation which depends on resource concentrations that we fully characterize in terms of the function $\varphi$.
adaptive2.pdf (215.51 Ko) Télécharger le fichier
inria-00488979 , version 1 (03-06-2010)
inria-00488979 , version 2 (09-03-2016)
Nicolas Champagnat, Pierre-Emmanuel Jabin. The evolutionary limit for models of populations interacting competitively via several resources. Journal of Differential Equations, 2011, 251 (1), pp.179-195. ⟨10.1016/j.jde.2011.03.007⟩. ⟨inria-00488979v1⟩
608 Consultations
187 Téléchargements
