Proof Trick: Small Inversions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We show how an inductive hypothesis can be inverted with small proof terms, using just dependent elimination with a diagonal predicate. The technique works without any auxiliary type such as True, False, eq. It can also be used to discriminate, in some sense, the constructors of an inductive type of sort Prop in Coq.
paper_1.pdf (98.78 Ko) Télécharger le fichier
inria-00489412 , version 1 (04-06-2010)
inria-00489412 , version 2 (27-07-2010)
  • HAL Id : inria-00489412 , version 1
Jean-François Monin. Proof Trick: Small Inversions. Second Coq Workshop, Yves Bertot, Jul 2010, Edinburgh, United Kingdom. ⟨inria-00489412v1⟩
Collections
COQ2010
942 Consultations
539 Téléchargements
