Automatic Parallelization in GCC: for Research and for Real (Keynote Talk) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Document Associé À Des Manifestations Scientifiques Année : 2010
Portability of performance has been the underlying assumption for the vast majority of software developments. Micro-architectures and run-time systems have been designed to hide the parallelism and non-uniformity of the hardware, but with diminishing returns in performance and poor power efficiency. Despite decades of successes with optimizing compilers, the complexity of modern hardware has incrementally destroyed this dream for most developers. Every day, more programmers are forced to resort to platformspecific optimizations, committing early on specific parallel implementations. This is a dramatic regression.
PESPMA-cohen-court.pdf (224.04 Ko) Télécharger le fichier
inria-00494301 , version 1 (22-06-2010)
  • HAL Id : inria-00494301 , version 1
Albert Cohen. Automatic Parallelization in GCC: for Research and for Real (Keynote Talk). Pespma 2010 - Workshop on Parallel Execution of Sequential Programs on Multi-core Architecture, Jun 2010, Saint Malo, France. ⟨inria-00494301⟩
103 Consultations
54 Téléchargements
