A formulation of the linear discrete Coulomb friction problem via convex optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Applied Mathematics and Mechanics / Zeitschrift für Angewandte Mathematik und Mechanik Année : 2011
This paper presents a new formulation of the dynamical Coulomb friction problem in finite dimension with discretized time. The novelty of our approach is to capture and treat directly the friction model as a parametric quadratic optimization problem with second-order cone constraints coupled with a fixed point equation. This intrinsic formulation allows a simple existence proof under reasonable assumptions, as well as a variety of solution algorithms. We study mechanical interpretations of these assumptions, showing in particular that they are actually necessary and sufficient for a basic example similar to the so-called ''paradox of Painlevé''. Finally, we present some implementations and experiments to illustrate the practical aspect of our work.
ptfixe.pdf (287.58 Ko) Télécharger le fichier
inria-00495734 , version 1 (28-06-2010)
Vincent Acary, Florent Cadoux, Claude Lemaréchal, Jérôme Malick. A formulation of the linear discrete Coulomb friction problem via convex optimization. Journal of Applied Mathematics and Mechanics / Zeitschrift für Angewandte Mathematik und Mechanik, 2011, 91 (2), pp.155-175. ⟨10.1002/zamm.201000073⟩. ⟨inria-00495734⟩
496 Consultations
1761 Téléchargements
