RoboCast: Asynchronous Communication in Robot Networks
This paper introduces the \emph{RoboCast} communication abstraction. The RoboCast allows a swarm of non oblivious, anonymous robots that are only endowed with visibility sensors but do not share a common coordinate system, to asynchronously exchange information. We propose a generic framework that covers a large class of asynchronous broadcast-based algorithms and show how our framework can be used to implement fundamental building blocks in robot networks such as gathering or stigmergy. In more details, we propose a RoboCast algorithm that allows each robot to asynchronously broadcast its local coordinate system. Our algorithm is further refined with a local collision avoidance scheme. Then, using the RoboCast primitive, we propose algorithms for deterministic asynchronous gathering and binary information exchange.
