Efficient Computation of the Pareto Boundary for the MISO Interference Channel with Perfect CSI - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider the two-user multiple-input singleoutput (MISO) interference channel and the rate region which is achieved when the receivers treat the interference as additive Gaussian noise and the transmitters have perfect channel state information (CSI). We propose a computationally efficient method for calculating the Pareto boundary of the rate region. We show that the problem of finding an arbitrary Pareto-optimal rate pair, along with its enabling beamforming vector pair, can be cast as a sequence of second-order cone programming (SOCP) feasibility problems. The SOCP problems are convex and they are solved very efficiently using standard off-the-shelf (namely, interiorpoint) algorithms. The number of SOCP problems that must be solved, for the computation of a Pareto-optimal point, grows only logarithmically with the desired accuracy of the solution.
p413-karipidis.pdf (235.37 Ko) Télécharger le fichier
inria-00499405 , version 1 (09-07-2010)
  • HAL Id : inria-00499405 , version 1
Eleftherios Karipidis, Erik G. Larsson. Efficient Computation of the Pareto Boundary for the MISO Interference Channel with Perfect CSI. WiOpt'10: Modeling and Optimization in Mobile, Ad Hoc, and Wireless Networks, May 2010, Avignon, France. pp.413-417. ⟨inria-00499405⟩
Collections
WIOPT2010
32 Consultations
97 Téléchargements
