Structural approach for building reconstruction from a single DSM - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Pattern Analysis and Machine Intelligence Année : 2010
We present a new approach for building reconstruction from a single Digital Surface Model (DSM). It treats buildings as an assemblage of simple urban structures extracted from a library of 3D parametric blocks (like a LEGO set). First, the 2D-supports of the urban structures are extracted either interactively or automatically. Then, 3D-blocks are placed on the 2D-supports using a Gibbs model which controls both the block assemblage and the fitting to data. A Bayesian decision finds the optimal configuration of 3D-blocks using a Markov Chain Monte Carlo sampler associated with original proposition kernels. This method has been validated on multiple data set in a wide-resolution interval such as 0.7 m satellite and 0.1 m aerial DSMs, and provides 3D representations on complex buildings and dense urban areas with various levels of detail.
pami_2010a.pdf (6.21 Mo) Télécharger le fichier
inria-00503136 , version 1 (28-01-2013)
Florent Lafarge, Xavier Descombes, Josiane Zerubia, Marc Pierrot-Deseilligny. Structural approach for building reconstruction from a single DSM. IEEE Transactions on Pattern Analysis and Machine Intelligence, 2010, 32 (1), pp.135-147. ⟨10.1109/TPAMI.2008.281⟩. ⟨inria-00503136⟩
329 Consultations
1113 Téléchargements
