A knowledge-based approach of seismic interpretation : horizon and dip-fault detection by means of cognitive vision. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
The present paper presents preliminary results obtained through a new seismic interpretation methodology based on cognitive vision. This methodology consists in associating to the geological objects to be detected, horizons or faults, visual characteristics that allow to easily identify and correlate them on seismic images. The results presented show that the method is performing well and is easy to be integrated in Shared Earth Modeling workflows.
SEG2008_Verney.pdf (1.35 Mo) Télécharger le fichier
inria-00507016 , version 1 (30-08-2010)
  • HAL Id : inria-00507016 , version 1
Philippe Verney, Jean-Francois Rainaud, Michel Perrin, Monique Thonnat. A knowledge-based approach of seismic interpretation : horizon and dip-fault detection by means of cognitive vision.. SEG, International Exposition and 78th Annual Meeting, Nov 2008, Las Vegas, United States. ⟨inria-00507016⟩
573 Consultations
821 Téléchargements
