On the confluence of lambda-calculus with conditional rewriting - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Theoretical Computer Science Année : 2010
The confluence of untyped λ-calculus with unconditional rewriting is now well un- derstood. In this paper, we investigate the confluence of λ-calculus with conditional rewriting and provide general results in two directions. First, when conditional rules are algebraic. This extends results of Müller and Dougherty for unconditional rewriting. Two cases are considered, whether β-reduction is allowed or not in the evaluation of conditions. Moreover, Dougherty's result is improved from the assumption of strongly normalizing β-reduction to weakly normalizing β-reduction. We also provide examples showing that outside these conditions, modularity of confluence is difficult to achieve. Second, we go beyond the algebraic framework and get new confluence results using a restricted notion of orthogonality that takes advantage of the conditional part of rewrite rules.
main.pdf (529.47 Ko) Télécharger le fichier
inria-00509054 , version 1 (20-09-2011)
Frédéric Blanqui, Claude Kirchner, Colin Riba. On the confluence of lambda-calculus with conditional rewriting. Theoretical Computer Science, 2010, 411 (37), pp.3301-3327. ⟨10.1016/j.tcs.2009.07.058⟩. ⟨inria-00509054⟩
202 Consultations
287 Téléchargements
