Texture-Based Visibility for Efficient Lighting Simulation - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Journal Articles ACM Transactions on Graphics Year : 2000
Lighting simulations obtained using hierarchical radiosity with clustering can be very slow when the computation of fine and artifact-free shadows is needed. To avoid the high cost of mesh refinement associated with fast variations of visibility across receivers, we propose a new hierarchical algorithm in which partial visibility maps can be computed on the fly, using a convolution technique, for emitter-receiver configurations where complex shadows are produced. Other configurations still rely on mesh subdivision to reach the desired accuracy in modeling the energy transfer. In our system, radiosity is therefore represented as a combination of textures and piecewise constant or linear contributions over mesh elements at multiple hierarchical levels. We give a detailed description of the gather, push/pull and display stages of the hierarchical radiosity algorithm, adapted to seamlessly integrate both representations. A new refinement algorithm is proposed, that chooses the most appropriate technique to compute the energy transfer and resulting radiosity distribution for each receiver/emitter configuration. Comprehensive error control is achieved by subdividing either the source or receiver in a traditional manner, or by using a blocker subdivision scheme that improves the quality of shadow masks without increasing the complexity of the mesh. Results show that high-quality images are obtained in a matter of seconds for scenes with tens of thousands of polygons.
TRadEsub.pdf (1.18 Mo) Télécharger le fichier
Format : Figure, Image
Dates and versions
inria-00509978 , version 1 (17-08-2010)
Identifiers
  • HAL Id : inria-00509978 , version 1
Cite
Cyril Soler, François X. Sillion. Texture-Based Visibility for Efficient Lighting Simulation. ACM Transactions on Graphics, 2000, 19 (4). ⟨inria-00509978⟩
214 View
322 Download
Share
