Interactive multiresolution animation of deformable models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1999
This paper presents an approach to animate elastic deformable materials at interactive rates using space-time adaptive resolution. We propose a new computational model, based on the conventional Hooke's law, that uses a discrete approximation of derivative operators on irregular sample points. It allows local refinement or simplification of the computational model based on local error measurement. We in effect minimize calculations while ensuring a realistic and scale-independent behavior within a given accuracy threshold. We demonstrate this technique on a real-time virtual liver surgery application.
Mots clés
multiresAnim.pdf (580.4 Ko) Télécharger le fichier
liver.wf.mpg (3.81 Mo) Télécharger le fichier
liver1.mpg (2.86 Mo) Télécharger le fichier
liver2.mpg (4.36 Mo) Télécharger le fichier
taylor.avi (11.38 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
Format : Autre
Format : Autre
inria-00510072 , version 1 (17-08-2010)
  • HAL Id : inria-00510072 , version 1
Gilles Debunne, Mathieu Desbrun, Alan H. Barr, Marie-Paule Cani. Interactive multiresolution animation of deformable models. Eurographics Workshop on Computer Animation and Simulation, 1999, Milan, Italy. ⟨inria-00510072⟩
495 Consultations
1839 Téléchargements
