Simplifying the Representation of Radiance from Multiple Emitters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1994
In recent work radiance function properties and discontinuity meshing have been used to construct high quality interpolants representing radiance. Such approaches do not consider the combined effect of multiple sources and thus perform unnecessary discontinuity meshing calculations and often construct interpolants with too fine subdivision. In this research we present an extended structured sampling algorithm that treats scenes with shadows and multiple sources. We then introduce an algorithm which simplifies the mesh based on the interaction of multiple sources. For unoccluded regions an a posteriori simplification technique is used. For regions in shadow, we first compute the maximal umbral/penumbral and penumbral/light boundaries. This construction facilitates the determination of whether full discontinuity meshing is required or whether it can be avoided due to the illumination from another source. An estimate of the error caused by potential simplification is used for this decision. Thus full discontinuitymesh calculation is only incurred in regions where it is necessary resulting in a more compact representation of radiance.
DrettakisEGW.pdf (193.09 Ko) Télécharger le fichier
inria-00510141 , version 1 (17-08-2010)
  • HAL Id : inria-00510141 , version 1
George Drettakis. Simplifying the Representation of Radiance from Multiple Emitters. 5th Eurographics workshop on Rendering, 1994, Darmstad, Germany. ⟨inria-00510141⟩
72 Consultations
148 Téléchargements
