Experiments with citation mining and key-term extraction for Prior Art Search
This technical note presents the system built for the IP track of CLEF 2010 based on PATATRAS (PATent and Article Tracking, Retrieval and AnalysiS), the modular search infrastructure initially realized for CLEF IP 2009. We largely reused the system of the previous CLEF IP but at a relatively smaller scale and with the improvement of three main components: • A new citation mining tool based on Conditional Random Fields (CRF). • A key-term extraction module developed for technical and scientific documents and adapted to patent document structures using a vast ranges of metrics, features and a bagged decision tree. • An improvement of our multi-domain terminological database called GRISP. We used the Okapi BM25 and the Indri retrieval models for the prior art task and a KNN model for the automatic classification task under the IPC subclasses. In both tasks, specific final re-ranking techniques were used, including multiple regression models based on SVM. Although the Prior Art task was more challenging and we used a more limited number of retrieval models, we maintained similar results as last year. We performed, however, miserably at the classification task, and we consider that an instance-based KNN algorithm is not competitive with standard classifiers based on preliminary large scale training.
Informatique et langage [cs.CL]
