Abstract : In the domain of soft real-time application design, the gap between component-specification models and the im- plementations often implies that the implementations can- not fully take advantage of the specification models. To limit this gap, this paper proposes an approach to generate a QoS monitor from the timed behavior specification. To support this approach, we rely on two different component models: one focused on formal description and the other on prac- tical implementation. Those models are interconnected by model transformation, using a Model-Driven Engineering style.
https://hal.inria.fr/inria-00512553
Contributor : Didier Vojtisek <>
Submitted on : Monday, August 30, 2010 - 6:09:24 PM Last modification on : Friday, January 8, 2021 - 3:39:49 AM Long-term archiving on: : Thursday, December 1, 2016 - 9:39:59 AM
Sébastien Saudrais, Olivier Barais, Laurence Duchien. Using Model-Driven Engineering to generate QoS Monitors from a formal specification. Proceedings of the Aquserm 2006, 2006, Hong Kong, China, China. ⟨inria-00512553⟩
