A Survey on Solid Reconstruction from Engineering Drawings - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Software Année : 2008
Jie-Hui Gong
  • Fonction : Auteur
Hui Zhang
  • Fonction : Auteur
Solid reconstruction from engineering drawings is one of the efficient technologies to product solid models, which has become one of the important research topics in both computer graphics and artificial intelligence. The problem of solid reconstruction from engineering drawings is captured. The taxonomy for solid reconstruction techniques is presented with the typical algorithms reviewed. After comparing the application areas of the algorithms, the open research issues are analyzed. Finally, the future work in the research field is also pointed out.
27_A_Survey_on_Solid_Reconstruction_from_Engineering_Drawings.pdf (273.14 Ko) Télécharger le fichier
inria-00515509 , version 1 (07-09-2010)
  • HAL Id : inria-00515509 , version 1
Jie-Hui Gong, Hui Zhang. A Survey on Solid Reconstruction from Engineering Drawings. Journal of Software, 2008. ⟨inria-00515509⟩
72 Consultations
207 Téléchargements
