Identification of Sections from Engineering Drawings Based on Evidence Theory - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
View identi¯cation is the basal process for solid reconstruc- tion from engineering drawings. A new method is presented to label various views from a section-involved drawing and identify geometric planes through the object at which the sections are to be located. In the approach, a graph repre- sentation is developed for describing multiple relationships among various views in the 2D drawing space, and a rea- soning technique based on evidence theory is implemented to validate view relations that are used to fold views and sections in the 3D object space. This is the ¯rst automated approach which can handle multiple sections in diverse ar- rangements, especially accommodating the aligned section for the ¯rst time. Experimental results are given to show that the proposed solution makes a breakthrough in the ¯eld and builds a promising basis for further expansibility, although it is not a complete one.
28_Identification_of_Sections_from_Engineering_Drawings_Based_on_Evidence_Theory.pdf (841.16 Ko) Télécharger le fichier
inria-00515523 , version 1 (07-09-2010)
  • HAL Id : inria-00515523 , version 1
Jie-Hui Gong, Hui Zhang, Bin Jiang, Jia-Guang Sun. Identification of Sections from Engineering Drawings Based on Evidence Theory. ACM Solid and Physical Modeling Symposium (SPM 2008), Jun 2008, New York, United States. ⟨inria-00515523⟩
54 Consultations
3752 Téléchargements
